Turn off Snapping in Drawing
neljoshua
Advisor Advisor
Message 1 of 10
neljoshua
Sometimes after creating a note or moving a dimension, I want to move it in order to clean a drawing up or make it easier to read.  The screenshot shows an instance where there are a high density of part numbers in a small area.  Moving them is a pain right now, because Fusion seems to want to snap to everything.  I would like a way to turn off snapping in the drawing environment to make this task easier and faster.
Fusion tries to snap to another balloon or the previous position of the currently-selected one.  In this picture, it is trying to snap to the "4" balloon.  I know there is a way to align the balloons.  My gripe, however, still stands, as the line used to align the balloons can also snap to everything.  Also, I have had issues with this when creating notes and moving dimensions.
Snapping can be useful in some instances, but in my opinion there should always be a way to turn it off.  Ideally this would be the same across all environments.
Perhaps there is a way to do this, but I cannot figure it out.  Pressing "cmd" or "control" does not prevent snapping.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Replies (9)
Message 2 of 10
cmiller66
Hi Josh,
Short answer, you're not missing anything, we don't support this (yet) but it is a very valid suggestion.  We do have snap improvements on the road map, but I don't have a timeframe for you.  I will forward this request to the team.
Chris
Message 3 of 10
neljoshua
@cmiller66,
Thanks for the info.
__
Message 4 of 10
So I have a very similar problem.  In most of my drawings I have no issue.  Snaps seem to work fine and I can move things around.  But I recently hit some random key combination that suddenly turned on some kind of grid snaps at every 6 inches or so.  Any idea how to turn off grid snaps on a drawing file?
Message 5 of 10
khokeson
Guys is there really still no way to turn off grid snap in drawings? I can't even properly mark up a drawing because notes snap to incredibly frustrating places.
Message 6 of 10
david29ZPM
To echo what is being said here, I also experience this from time to time. I was just editing the scale of a view, adding some leaders and at some point snaps randomly got turned on for just one page of my drawing, it's extremely frustrating. Is there still no solution?
Message 7 of 10
boltsonsite
Observer
Observer
2025 and still no fix??? trying to rotate a part in a detail drawing but snaps are driving me mad!!!!!
Message 8 of 10
ccyokes
Hoping this gets added someday... literally just disable snapping while holding the control or alt key. Would be simple and quick to implement and save a lot of actions either zooming way in to get enough pixels between snap points or going into the right click menu for every action to disable the snapping one point at a time.
For the included photos, you can see that in some situations a line REALLY wants to snap rather than allow you to place it wherever you want. This was taken while adding a sketch to a drawing. Adding manufacture details that aren't in the model, things that are far easier to annotate after than try to model in. The right click menu while you have the tool selected at least allows it, but a hotkey would be much preferred. Control for no snap, alt for mid snap? Those are the two I would like at least.
Message 9 of 10
g-andresen
I would just like to point out that this topic was about the behavior in drawing mode, but not in sketches.
Deactivate these settings in the preferences and create snap points with the projection tool.
günther
Message 10 of 10
ccyokes
The behavior is closely related as it has to do with curser snapping across all sketching and dimensioning methods. My example was demonstrated in one area, but it applies to many. Projection would remove potentially unneeded lines in some cases, but the root of the issue is still snapping behavior and the request to have snapping be able to be disabled at will at the push of a button rather than toggling modes for every action.
When I get the chance I will experiment with disabling those, but I’m pretty sure that will have other consequences for features I use that will make it not worthwhile here.
