Tubular Chassis Force Simulation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there
Im busy building a motorcyle powered kart for my kids. Ive started out with a simple ladder frame, which I will now be adding structural elements (diagonal members, shear plates etc) to create beaming and torsional stiffness.
The issue Im running into is how to approach a tube structure when modelling. > As you can see, Im failing to join the seperate pieces of tubing.
Chassis v6: Study 1 - Static Stress: _____ 2016-04-09 12:32:43 _____
Chassis v6: Study 1 - Static Stress: Warning: Body 'Chassis v6:1/Component1:1/Component2:1' uses voxel mesh. Adaptive mesh refinements are not supported for this body.
Chassis v6: Study 1 - Static Stress: Base mesh: 38295 nodes, 20791 elements
Chassis v6: Study 1 - Static Stress: Solver mesh: 38295 nodes, 20791 elements
Chassis v6: Study 1 - Static Stress: Warning: Model separates into 4 independent groups of bodies
Chassis v6: Study 1 - Static Stress: Warning: Soft spring was added
Chassis v6: Study 1 - Static Stress: Number of equations solved: 114885
Chassis v6: Study 1 - Static Stress: Solution time: 1.3s
