Tube hole pattern template printout
final_fronti
Observer Observer
final_fronti
Observer
Observer
Dear Members,
My name is JR and I am new to this forum. I have been using Fusion 360 for a few months and I must say that it is a great tool for hobby and open source projects (I used to work with Freecad).
I am currently working on developing a small VTOL plane. I use an 80 mm PVC tube as basis for the fuselage. In this PVC tube I need to drill holes, so I can mount some brackets to it. I designed all mounting holes in a 3D model I made from the PVC pipe.
I would like to print the hole pattern on paper, so I can glue it to the outside of the PCVC tube. In this way, I can easily drill the holes on the correct locations, however, I am not sure if making such a drawing is possible?
Is this possible? If yes, can you please give me some advice to get me going.
JR
jhackney1972
Take a look at the video to explain the process.  As I mentioned in the video, you may have to adjust the tangent plane and/or the sketch split to keep the sheet metal gap away from your holes.  The size holes is up to you, the smaller the better for drill lineup.  I used 10mm holes just for demo.
Let me know if you have any questions.
(view in My Videos)
John Hackney, Retired
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
Theoforus
Just stopping by. Learned a lot from your video. I guess if you added some cross center geometry to the holes in the drawing it would be easier to get the drilling dead center with a pilot hole first.
I am just amazed by you helpful guys at this forum. So helpful and patient with us newbies. Have a nice day.
final_fronti
Observer
Observer
Dear John,
Thanks for your reply and accompanying video, it really helped my to be able to continue with my project.
JR
