GEAR ANIMATION
GEAR ANIMATION
20100956
GEAR ANIMATION
20100956
Community Visitor
Community Visitor
Hello, I am a college student who urgently used Fusion360 for my assignment. The part where I'm in trouble is making an animation. I am currently notified that I cannot bond to create an automata using the principles of radial engine. Help me!!
jhackney1972
Please attach your model for help and fully explain the motion you need.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
etfrench
Use slider joints for one end of the arms and revolute or cylindrical for the other end.  Add a revolute joint between the center cylinder and the base.  The base should be grounded.
If this doesn't work for you, attach your model.
ETFrench
