TTY fonts
TTY fonts
skipb48
TTY fonts
skipb48
Is there a way to have a Fusion only show me TTY fights in their final list? Currently, on my iMac, it shows all the fonts available, most of which I cannot extrude in my files.
johnsonshiue
Hi! I could be wrong but I don't believe there is a filter to do that on Mac or Windows.
Many thanks!
Software Test Engineer
skipb48
Too bad, maybe the programmers will see this and think about, including it in future updates. It is quite frustrating to pick a nice font and then find that it won't print the way you wanted to.
skipb48
I think I found a work around. I discovered that if I use a font like Ariel then extrude it and finish the sketch, then go back and edit the text changing it to some other text that previously could not be extruded Fusion will change the extrusion to the new text. The key is when you edit the sketch you then have to right click on the text itself to display the Edit Text command to change that text.
