Trying to Shell a simple Sweep
2herds
Message 1 of 9
2herds
Just started learning about Sweep by making some simple examples (just a small curved sweep) and found the Shell didn't work on Sweeps. Looked over other posts and unchecked the tangent chain, no help. Changed my models to cylinder, box, pipe, ... etc., and Shell works fine.
Replies (8)
Message 2 of 9
TheCADWhisperer
File >Export and then Attach a *.f3d file here that exhibits this behavior.
Message 3 of 9
2herds
Sweep_Shell v0.f3d
Hope I did this right?
Message 4 of 9
2herds
I may have just found the problem relating to the Orientation. It seems if in the Parallel mode it will Shell, but not in the Perpendicular mode. (I think?)
Message 5 of 9
sanket223.patil
Did'nt got the file . Export file and attach file here . OR share the public link .       I tried the shell on simple sweep , it was working . Share your file so we can help you .export.png
Sanket Patil
Mechanical Engineering
Expert Elite
Message 6 of 9
2herds
I have the file saved on drive. When you say attach "here" I am not sure where "here" is. OK I am slow. 😞
Would you tell me exactly the procedure where to put the saved file so it gets to you.
Also, did you notice my post when I changed the Sweep orientation to Parallel it did work, but does not work in Perpendicular.
Message 7 of 9
TheCADWhisperer
Reply via the web forum - not by email.
Message 8 of 9
chrisplyler
Message 9 of 9
chrisplyler
