Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Trying to make a cut
3 REPLIES 3
490 Views, 3 Replies
Im trying to make a cut on the blue surface, the cut begins when it reaches the other surface.
Im trying to use the split tool but i think im using it wrong. if someone could help me that would be appreciated ! thankyou
3 REPLIES 3
davebYYPCU
in reply to: 19297154
From the left, - right or bottom?
in reply to: davebYYPCU
so i want it to stop at the black line, and get rid of all the yellow shaded part basically
davebYYPCU
Should be able to use your black line as a cutter for split body, if it is a body,
If it is a sketch then you could trim the right side away, but
Either way you cant do anything to the linked component.
