Trying to finish loft from vertical to horizontal with taper
drakeburgoon
drakeburgoon
I have been fighting this design for a while and cannot figure it out. I drew a rib of the finish profile I want. I thought this would be an easy loft function but I have been fighting it for hours without being able to figure it out. Any help would be greatly appreciated.
drakeburgoon
A couple pictures to maybe help.
wersy
If the parts fit together exactly it should go.
drakeburgoon
That's exactly what I was trying to do. How did you do it?
wersy
I don't it is what you want.
Nothing fits together. You must design carefully.
I add a sketch.
What I did is rubbish 🙂
johnsonshiue
Hi! Here is a solution without using Loft. Instead of Loft, I used Revolve and Non-Uniformed Scale. Though the resultant geometry isn't dimensionally accurate per sketches, the technique creates much smoother geometry and it is easier to control the outcome.
Many thanks!
Software Test Engineer
