Sketch Alignment -Newbie
ruafrog
ruafrog
I am just getting starting and can't seem to find an answer to this question. I'm sure it's out there I'm just missing it!
How can I align these lines to each others at their center point, then group them to align in the center of the circlfusionAlignmentQuestion.pnge?
jeff_strater
many ways to skin this cat.  One way uses all coincident constraints.  The trick is holding down Shift to infer the midpoint of the vertical lines.
Jeff Strater
Engineering Director
ruafrog
Thank you! You have saved my head from banging against the wall!
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
Time spent on the tutorials and self paced learning will not be wasted. Also check out the three RULES that are pinned
to the forum for further guidance.
Cheers
Andrew
