Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Typically when I want to extrude a body in the opposite direction of the arrow, I just make the value negative and carry on. But for this particular application, I am trying to find some other way to do it. This is because I want to make the extruded value a defined parameter, so if all of the extrusions aren't oriented in the same direction, I'll get some going the right direction and some going the wrong direction. Is there some way to reverse the direction of that extrusion arrow so I can orient them all in the appropriate direction?
Thank you kindly.
