Trying to combine two different sketches, having difficulty
eisenmanguitars
eisenmanguitars
I'm trying to design a pickguard to be machined to look like tooled leather.  I first made the outline with a 1/8" border, then created a new sketch to draw in the hours of tooling.  I needed to trim the edges of the tooling flush with the border, but my trim function wouldn't work with them being in separate sketches.  I edited the 2nd sketch, then projected the first sketch (outline and border) onto it, and things aren't lining up quite right, and some lines aren't connecting.  I haven't been able to use constraints, because maybe half the sketch is just a projection at this point?  Can anyone help me "join" these two sketches, or fix the misalignment issue?  It is most obvious in the couple tooling shapes at the top of the pickguard.
Second question, after I get this part figured out, I want to make these tooling shapes project upward smoothly.  Should I use the fillet option for this?
g-andresen
delete those contours und create new ones
(view in My Videos)
günther
eisenmanguitars
Thank you!
