- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Here is the situation I have; I'm trying to flip a part 3 times. op1 is the main body of the part. op2 is flipping the part 180 and facing off the hat and machining my fillets both op2 and op1 are good with origin. when I try to go to my op3 this consists of the rotating the part on its side 90 degrees so I can pop 2 holes in the part, I can't get the origin to do what I need it to do in the work coordinate system, I can't set my y axis vertical only horizontal, I know the origin relates to the original origin when it was drawn. is there any way to add another origin that doesn't correspond to the original or make it so I can freely use the WCS without corresponding to the original drawing origin, any help would be appreciated.
