Trouble with firefox
不适用
381 次查看
1 条回复
1 条消息(共 2 条)
不适用
When I go to my project's web page and export a design I am sent a link to download. This link doesn't work as expected if I use Firefox. For instance if I export a design called "Ball Spacer.xxx" (xxx is one of the supported extensions) the file name is changed to "Ball.xxx". This does not happen if I use Edge (The Windows 10 browser). Any idea why?
0 个赞
382 次查看
1 条回复
回复 (1)
2 条消息(共 2 条)
mstrater
This appears to be a issue on our end. Details here if you are curious: http://kb.mozillazine.org/Filenames_with_spaces_are_truncated_upon_download
I've logged a bug (internal reference ATEAM-7441) for us to look at it, but the link above also suggests using a Firefox extension (http://www.polarcloud.com/truncfix) as a workaround.
Good catch!
Max Strater
Sr. Software Engineer
