Trouble with Converting Volumes in Parameters to Parameters for Dimensions
JohnJSS
JohnJSS
I am try to set up a parameter to solve for the radius of cylinder given a volume and height but I can't figure out where I am going wrong.
jeffescott
Looks like your missing a bracket?
HughesTooling
Easier to help if you share the file. You will need to cancel the units so something like ((Volume_liters/l)/(PI*Height/mm))^0.5 to cancel the units for the volume and the height.
Edit, looks like that only gives you an answer as cubic mm so need to multiply by 1,000.
((Volume_liters/l)/(PI*Height/mm))^0.5 * 1000mm
Mark Hughes
Owner, Hughes Tooling
g-andresen
It should be noted that 1 l = 10^6 mm^3.
       1,272 l = 1,272 * 106 mm3
günther
