Trouble using Joint Revolve on a 4 bar linkage
david_vonpaumgartten
I'm trying to use joints to put together this 4 bar linkage, but as soon as I create Revolute 8 to complete the linkage, I get an error at Revolute 4. Does anyone have any tips or advice?
jhackney1972
You should have export a native Fusion model as an F3D or F3Z file.  If you have trouble attaching it to your Forum post, first ZIP it.  When faced with multiple linkages, sometimes a Cylindrical Joint is needed to relieve slight alignment errors.  In this case it was not.  Model attached.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
I see. I'm sorry. Thank you for your help.
