- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm attempting to draw a 2 point rectangle and then move it. I place the first corner at the origin of the sketch and the other at an arbitrary grid point, let's call it a 2 x 2 square. When I attempt to Move the square I am unable to , which I believe is because of the constraint automatically applied to the first corner. There are two Coincident Constraints applied to the first corner, one for the origin (constraint on the left) and one for the corner of the square itself (constraint on the right).
If I delete the Coincident constraint on the left (coincident to Origin), it disappears and the Coincident constraint for the corner remains, and I am free to move the square along the sketch plane. However if I delete the Coincident constraint on the right (corner of the square) both constraint symbols disappear from view but I am unable to move the square. The Coincident constraint to the Origin remains in effect, yet I cannot see or delete it.
Why does this occur, and how is it intended to benefit the user?
