Trouble selecting surface
Message 1 of 8
I am new to F360. I am trying to project an svg to a surface. Tried to create an offset plane above. Everything I do it wont let me select the surface, I am assuming its something simple that I am missing.
Replies (7)
Message 2 of 8
TrippyLighting
You have to create a new sketch on that surface and then project into that sketch.
Message 3 of 8
That didn't solve it. It won't let me select the surface.
So I created a form. Clicked finish form. But when I try to use that form to reference a surface/plane I can not select it.
Message 4 of 8
TheCADWhisperer
A sketch must be started on a workplane or on a planar face.
If you do not have any planar faces and you cannot use an Origin workplane - then you will need to create a workplane.
You cannot create an offset workplane if the original face isn't planar - you will have to use some other technique to create the workplane.
Message 5 of 8
Here it is.
Message 6 of 8
TheCADWhisperer
Can you attach the *.svg file?
I assume that all you need to do is offset the XY plane above your part, start a new sketch on the offset plane and then Insert the svg to have it ready to use.
Message 7 of 8
I tried that, and it wont allow me to select surface.
Message 8 of 8
TheCADWhisperer
You keep saying "select surface".
You do not have any planar surfaces.
You need to create a new workplane offsetting the XY plane.
I had no trouble inserting the svg file.
Download attached.
File>New Design From File and select file.
Actually, you don't even need to offset the XY plane, you can simply create the sketch on the XY and insert the image.
