Hi All
I was working on some designs when I found to was difficult to select lines , construction lines, when the where on top of each other, even the control lines on splines where in the way.
i.e
in the above picture there is 2 construction lines and normal line on top, once you have stacked lines how do you select the lines under .
In other system, I would sign each line a different colour , then use a filter to select the line I wanted or I could hide the lines I don't want
I can't figure out how to do either in fusion?
Cheers, Stephen
