Trouble projecting sketch onto faces.
I'm having trouble while trying to project a sketch onto multiple faces. Whenever I select the curves in the sketch, I always get the error: "Warning: Not support projecting sketch geometry into same sketch, please change the target sketch or geometry." Can anyone be of assistance to help?
HughesTooling
The warning tells you what's wrong. You can't project a curve to a face if the curve is in the current active sketch. You need to create another sketch and project the curves from the first sketch.
Mark
Mark Hughes
Owner, Hughes Tooling
