Trouble Patching area on design
danotranto
Message 1 of 14
danotranto
Having a bit of trouble patching this area of a guitar neck design I'm working on. Dunno how to trouble shoot it, program is constantly crashing when trying to figure it out too.
Replies (13)
Message 2 of 14
TheCADWhisperer
@danotranto
Given all of the unresolved issues highlighted in the Timeline - if this were my design I would start over from scratch and use what was learned in this attempt.
Are you trying to follow a tutorial?
If yes, what is the link?
This arc has an illogical radius, and I would expect it to be tangent.
Or have a straight line between the curves.
Message 3 of 14
danotranto
I did follow a tutorial for one part that seems to be working out:
I'll start this one over.
Message 4 of 14
TrippyLighting
You missed a few loft settings to get that area patched. In my surfacing work, I almost never loft or patch between sketch entities, even it might be OK. I'd rather have a few unnecessary helper surfaces, but I never accidentally pick a sketch object when I need an edge, and if I need to change loft settings, I have options with a surface edge I don't have with a sketch object.
(view in My Videos)
Message 5 of 14
TrippyLighting
Here is another video explaining how to create better surface quality on the other end. This requires a workaround for a bug I reported a year ago.
(view in My Videos)
Message 6 of 14
johnsonshiue
Hi! I am wondering if it would be easier to create the clear intersection (without the blend) and then use Asymmetric Fillet to create the blend faces.
Many thanks!
Software Test Engineer
Message 7 of 14
TrippyLighting
Nope! I just tried it and it can't create a fillet, which isn't unexpected.
Message 8 of 14
danotranto
Thank you!
I did re-do the sketch, had forgotten to use the helper surfaces.
Do you have recommendations for best practices when creating stuff like this? My projects always get incredibly messy with tons of sketches trying to bodge things together.
Message 9 of 14
TheCADWhisperer
@danotranto
Are you ready to start over from scratch?
Message 10 of 14
danotranto
I did re-do the project, wound up getting pretty messy again.
Having trouble going back into the project to make some of the patched areas tangent. When I go back in the timeline and unstitch everything it doesn't have any drop down menu for the edges to make them tangent (or curvature, etc).
My program is having a really difficult time with the timeline, it's not behaving as intended where you select an operation in the timeline and it will highlight that on the part, this only works like 1 out of 30 times.
Message 11 of 14
TheCADWhisperer
@danotranto
You are working too hard.  This can be simplified.
Also, your tool is going to break through here...
Message 12 of 14
danotranto
I wound up getting this part made, some issues with the file I'd like to adjust but can't seem to figure out how to go back in and change things.
In this picture you can see some strange ghosting or very subtle ridge in the part right at an area of patching. There is also a sort of sharp ridge going lengthwise, another area that had been stitched. I believe this was caused from not using the correct type of patch, and I should have used tangent, I'm having some difficulty going back in to do this, any advice on how to unstitch, change patch type and then re-stitch easily? My timeline is quite messy. I've unstitched the part but it will not allow new patching to be changed to tangent or curvature.
https://a360.co/3RE348m
Message 13 of 14
TheCADWhisperer
@danotranto
Why did you use a mirrored spline rather than an arc?
Should Sketch12 be symmetrical (I added the horizontal construction line)
Message 14 of 14
danotranto
Thanks for taking a look at this. Sketch 12 probably should be symmetric, but I'm just using these arcs as helper surfaces and I believe how long they are doesn't matter as long as the radius of the arc is the same (which I believe it is).
For some reason my program is not going to the timeline position when I select to edit a feature.
When I go to switch to tangent in patch it gives me this error.
