Trouble parameterizing components
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having trouble figuring out how to model and assemble a series of components such that a number of dimensions are parameterized. Here's the work-in-progress:
The two hanging flat pieces are linked components. The horizontal flat piece is a separate component (which will eventually have a linked pair on the opposite side). I want to parameterize the widths and lengths of everything separately, but I want the three pieces to be assembled together in a rigid assembly, and stay that way despite parameter changes.
Moreover, I want them to remain centered on the origin.
There is a revolute joint between the hanging pieces and the axle. The axle is currently grounded. I had tried to make the second hanging component with a parameterized move, but it seems I can't get back to edit that move.
Should those plates be bodies of one component, instead? What's the best way to specify the overall width, and have the cross plate grow and shrink, but always stay attached to the hanging plates?
Thanks!
