Trouble editing imported sketch curves
Hey there,
I'm trying to edit some imported SVG geometry. Is there any documentation on editing sketch paths (like keyboard shortcuts/modifiers)?
I'm trying to nudge this vertical line to the left by a tenth of an inch or so. I've built a bunch of geometry on this feature, but when I go to set up tool paths, it's too narrow to cut with the tool I want to use.
To do this in illustrator, I would select the line and the two connected points at each end with a lasso select. I'll then hold shift and drag left. I'll need to fix up the spline handles.
If I try this in Fusion, the connected lines move in unexpected ways:
If I try to fix the point at the top, then this happens:
I don't see any way to show the spline handles for these curves, but maybe I'm just missing something?
Are these imported sketches indeed represented internally as splines? Would it be possible to expose editing tools similar to the spline editing tools for them?
Thanks a bunch!
-c
