Trouble creating custom drawing view
Hi all....
I am trying to create a custom drawing view of a part from an assembly. I need the view to be normal to the face of an angled part. I have tried creating the custom view required but it is missing from the drawing view dialog when trying to create the part view from the assembly. Please see screencast attached. Any help would be greatly appreciated.
Many thanks
jhackney1972
The file you are working with is a Linked Component.  You can make a drawing from the assembly of the Linked Component but the drawing view is controlled by the assembly.  Take a look at the screencast and you will see that I created the Named View in the Assembly I wanted of the component, then I create the drawing for the linked component using the Named View created in the assembly.  You are making the drawing from the assembly, not the component.
John Hackney, Retired
That works perfectly for what I need, thank you!
Just need to get my head around the Fusion way of doing things...
Many thanks again
