trimming Lines
trimming Lines
Message 1 of 9
trimming Lines
New to Fusion 360. I have a component that has a line protruding out of it and I cant figure out how to delete it. Please Help.
Replies (8)
Message 2 of 9
lichtzeichenanlage
Is this an imported component or something nativ done in F360? A link to or an export of the design would be helpful.
Message 3 of 9
It was done completely in 360. Its keeping me from being able to fillet that edge.
Attached file for review.
Message 4 of 9
lichtzeichenanlage
I don't have a solution, but IMHO it's related to the Extrude 32 / cut
Message 5 of 9
I_Forge_KC
That's not just a line... it's actually a really REALLY tiny solid section.
Check this out...
This is just after Extrude33
Notice the edge I have selected has a 0 for delta X and delta Y.
Here we move forward one step (Extrusion32)
Notice the line is no longer square! This is because the distance chosen for Extrusion32 does NOT meet up with that edge.
So fixing it...
Edit Extrusion 32 and change it from a distance to a TO option. For the reference on the TO, select the point out to the left (see it in my image?)
And there you go. Fixed.
To be honest, there is lots of weirdness in this model. I have a feeling you will continue to have problems unless you re-think how you do some of the steps. I see you're undoing or changing features by adding more features instead of editing in place. Not a good plan...
K. Cornett
Generative Design Consultant / Trainer
Message 6 of 9
SaeedHamza
This is an imported component, please provide the original file of it with it's timeline
Regards
Saeed Hamza
Message 7 of 9
lichtzeichenanlage
@SaeedHamza: He did with this post, didn't he?
Message 8 of 9
TrippyLighting
Yep! Some of the weirdness and the reason for this particular artifact is already visible right in the the first sketch that everything else is based on. It is not fully defined / dimensioned and that results in lack of precision.
I'd redesign this from scratch and make sure all sketches are fully defined/dimensioned.
Message 9 of 9
Ok thanks, new to fusion 360 its a lot different than Sketchup that I was  using. Is there a good online tutorial that will go through most of the features and how/why to use them?
