trim, SLOW PROCESS.
trim, SLOW PROCESS.
trim, SLOW PROCESS.
Hi
I have been playing with designing patterns. But when trimming and extruding usually takes a long time. If I start trimming, its smooth. But when I have about 50+ lines done and am selecting more it slows way down. after a while it takes about 20 seconds to trim each line
here is a video of what I mean... it takes about 5 seconds from the time I click on a line to when it disappears
TheCADWhisperer
Pattern Features rather than sketches, but why do you even need to trim?
I find that if I don't trim the lines still come up when I'm exporting it to dxf for the waterjet machine.  Ill check out the patter features
TheCADWhisperer
Can you File>Export and then Attach a *.f3d file here that exhibits this behavior when the dxf is exported?
 I have attached the file. And on this case, it also takes along time to select the profiles I want to extrude?
etfrench
You don't need to trim the lines although it does make it easier to select the profiles to extrude.
After extruding, create a new sketch on the face of the extrusion (In Preferences|Design, make sure 'Auto project geometry on active sketch plane' is checked.)
Export the new sketch as dxf.
ETFrench
chrisplyler
Or...if you don't like to have Auto Project turned on...you can manually Project the face into the new Sketch. It just takes three clicks.
