Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Trapezoid with rounded corners
4 REPLIES 4
DavidTBEXZ
113 Views, 4 Replies
I'm having trouble getting the drawing i need in to the correct specifications,
I want to create a shape with the sketch dimensions set to the inside of the radius and for the radius to automatically fall between the angle created by this spec.
I have no idea what features or steps i should take to create this.
Ive attached photos of where im at so far and where i what i want to create.
Any help or suggestions is appreciated.
Fusion file: https://a360.co/3SQQyAh
Screenshot 2024-08-14 140705.pngPhoto Aug 14 2024, 1 58 06 PM.jpgPhoto Aug 14 2024, 1 58 12 PM.jpg
4 REPLIES 4
Warmingup1953
in reply to: DavidTBEXZ
Is there a single drawing that has all the information?
DavidTBEXZ
in reply to: Warmingup1953
This is the drawing With all the information i have,
Thanks for your help.
Warmingup1953
Ok as I see it with a quick look there is detail missing. Can you tell us your aim? Is it a gasket of some sort?
Edit: Maybe it's all there let me peruse,
Edit 2: Yes with an assumption (or two) it can be Sketched. Aagain what is your aim? Inches I assume?
jhackney1972
You best approach to sketching this, in my opinion, is to place all the outside corners as circles placing one of them on the Origin since it is denoted as 0,0.  Sketch tangent lines between them and trim as necessary.  Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
