Toolpath for "contour" including a vertically rounded edge
- Mute
- Permalink
- Report
I'm cutting a block of foam down to fit a lid of a Pelican case. My current work flow is to measure the radius and use a calculator to figure out my stepdown based on the width of each stepdown being no more than .2" so that I don't leave any material behind with my .25" endmill.
Some Pelican lids include ribbing in the corners or some structural bands running along the width. That makes my method complicated and ugly. Additionally, most Pelican cases are slightly tapered inside, so I have to find the smallest circumference and extrude/inclusion down to get right angles.
I have to assume there's a way I can just tell Fusion to start at a point and circle round and round until it clears everything. I have managed to use the 3D Contour to get those steep tapered sides, but I just can't get the radiused edges. I've attached the model of the case directly from Pelican; STEP files in a zipped folder. You'll have to create a patch and then boundary fill to get the "blank". I've also attached my Fusion file with my contour attempt.
I've watched videos about the contour, scallop, and blend, and I just can't seem to grasp it. My stock is always 20x24" and the thickness is exactly the height of the model every time. My endmill is an Amana 46272-K, for your size reference. I keep the DOC at .75" max, .2" stepover max (Except where I have to take a full width cut of course. The foam is super forgiving, so I can run the thing at 24000 RPM, 6000 mm/min no problem.)
I don't mind if there are cusps left over. It doesn't have to be smooth or pretty, it just has to fit in the lid and I want it to be more straightforward than splitting the model into layers and using multiple extrusions and 2D contours. Thanks!
