Title block not visible
tjstephens
Message 1 of 8
tjstephens
I've created a drawing from a part, and it seems that there's no title block in the sheet. The Sheet Settings dropdown has the title block section greyed out -- what am I missing?
Replies (7)
Message 2 of 8
cmiller66
Hi tjstephens,
The titleblock should be inserted with the border at the time of drawing creation.  By default, based on the units in the design (mm/in) the drawing settings should follow suit, ISO defaults for mm and ASME for in.  The fact your menu item says just "Title Block" vs. "ASME Title Block" or "ISO Title Block" makes me think something is not quite right in your preferences.
Can you expand your user menu (upper right) > Preferences > Drawing, and see what your default settings are?  If you always work in one Standard (say ASME with inch units) you can specify those here instead of the "Inherit From Design".  If you work in a mixed environment and want to keep "Inherit from Design" as the default can you change the settings here > Apply > OK > restart Fusion, then re-launch Preferences and set to your preferred setting?
Please let me know how it goes, we've had a few reports of this in the past and a hard reset of Preferences has taken care of it.
Chris
Message 3 of 8
tjstephens
I reset the preferences to defaults, and reselected ISO drawings. This seems to be working now for me.
Thanks!
Message 4 of 8
scottmoyse
I couldn't get the title block to work either when I had anything other than default settings in the Drawings section of preferences. However, the Title Block check boxes were showing up for me.... this looks like a bug to me.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 5 of 8
innovatenate
Autodesk Support
Autodesk Support
Can you post a screenshot of the preferences you are using? I tested changing mine, but have not reproduced the issue so far.
By title block check boxes, do you mean the check boxes in the navigation bar at the bottom?
Nathan Chandler
Principal Specialist
Message 6 of 8
thurgashinii
Community Visitor
Community Visitor
Hi . Why the part and title block are visible in detail drawing
Message 7 of 8
thurgashinii
Community Visitor
Community Visitor
 its visible
Message 8 of 8
g-andresen
please start a new topic
günther
