Tips for selcting plane when projecting an object to plane?
jskinner58
jskinner58
Recently had trouble with projecting an object to a plane and it turned out to be operator error.  I am still unclear how best to select a sketch plane.  If you have an sketch on the plane and click on the sketch you (apparently) only select that portion of the plane.  Is there an easy way to select without going back to the origin?  Looking for some tips on this, maybe a video that goes into some detail.
innovatenate
Autodesk Support
Autodesk Support
Perhaps you could use the "select other" tool to be more precise with the selection?
You should be able to specify whether you are selecting a sketch or a plane. Check out the below link for detail.
http://www.autodesk.com/products/fusion-360/blog/tip-tuesday-using-select-other-to-make-selections-e...
I hope that helps!
Nathan Chandler
Principal Specialist
