Message 1 of 10
Tie Rod Assembly to frame
06:27 AM
- Mute
- Permalink
- Report
Im looking to assemble this tie rod I've created that is going to be assembled in between two joints, a hub and steering column.
The points are not in line hence the ball joint.
Ideally I want to fix one end to the joint on the hub and then select the other end and get fusion 360 to work out the angles etc.
The tie rod Ive made has a ball joint and the threaded piece is on a slider joint but it doesn't seem to work. Or do what I want it to do.
Any help appreciated.
s
