[Threads] Validating the specifications of Autodesk thread dimensions
auke.westerterp
auke.westerterp
In Fusion 360 I have numerous options to add a thread with generic dimension. I want to choose a thread for which I do not need to design my own cap, but buy a standard thread.
The cap I want to use is most likely a DIN 45 cap fitting on a neck with the following specs:
If however I choose the DIN options in the following Fusion 360 menu I get very different dimensions and not the option I am looking for. I suspect the DIN pipe threads are not related to the threads use for standard (European) bottle / jerrycan threads:
The most likely variant I am looking for is the ISO metric profile with a 45mm thread with a 4mm pitch, but I would be very much helped if someone could confirm:
The bottlecap I am about to buy is usually referred to as a DIN 45, GL45, Ø 45 or 45 OV cap. I'll add a picture:
Is there a more specific description for the threading options Fusion 360 offers me?
yihua.mo
Hi Auke,
Currently Fusion provide most common thread types for user, so there is no thread option for bottle / jerrycan thread.
If you are creating a cosmetic thread, the ISO metric profile M45x4 will looks like a DIN45.
But if you are creating a physical thread("Modeled" is checked), it would be a new requirement for us. Because currently Fusion can build 4 kinds of shaps for thread: 1----trapezoid; 2---sharp; 3----square; 4-----withworth. The DIN45 thread is buttress thread, we need add new function to support this kind of thread profile.
If you strongly want to build bottle/jerrycan thread in physical way, please post a requirement in IdeaStation for Fusion product team.
Thank you!
Michael
PhilProcarioJr
Yes post this in the idea station please, it will get my vote.
Phil Procario Jr.
Owner, Laser & CNC Creations
