threads to screw together
I have a sphere which I hollowed to 3mm then cut in half.  I built a 2mm ring around of each the rims then put threads on the inside and the outside. The threads on the inside kind of worked but the outside just fell apart.  Do I need a thicker ring to do this?  Will a PVC printed version work out any better?
TheCADWhisperer
What diameter is your sphere?
TrippyLighting
Please share your design by exporting it as a .f3d file and attaching it to yur next post.
http://a360.co/2pswNhQ
hope this helps
have enlarged rim w thread
evened out the rim.
