Threads disappear after offset applied
tonyAQW8H
Message 1 of 15
tonyAQW8H
Image A shows what happened after I created a block with three tapped holes with an offset added to the middle hole thread - the thread on the middle hole disappeared. It should also be noted that the 2 remaining threads now have a bad thread form - the thread goes to a point rather than being truncated.
Image B shows what happened when I suppressed the offset feature - all 3 threads are visible and the thread form is correct.
Image C shows what happened when I suppressed the chamfer feature rather than the offset - all 3 threads are again visible with the correct form but the offset has failed.
After playing around a bit a full solution was found by moving the hole counterbores to after the thread feature, ie thread all of the holes all the way through, apply the offset and then add the counterbores.
Is this a how this is supposed to work?
Replies (14)
Message 2 of 15
TheCADWhisperer
Message 3 of 15
tonyAQW8H
Here is the requested file.
Message 4 of 15
MRWakefield
I always add the chamfer after the thread otherwise you get an odd anomaly where the thread doesn't run all the way through, as shown in these screenshots of your file.
I also noticed that your offset is only being applied to 5 faces. This should be 9 faces (see explanation below).
When applying offsets to threads to give more clearance or whatever you need to select the minor, major and just one of the flanks. This will keep the thread profile correct. If you select both flanks it will result in a thinner crest and a wider root.
I've attached a modified file that should be what you're looking to achieve.
Hope this helps.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 5 of 15
MRWakefield
Here are some more screenshots showing the problem with putting the chamfer before the thread.
Notice how you don't see the thread 'emerge' through the chamfer on your original:
Here's how it should look:
Marcus Wakefield
Message 6 of 15
g-andresen
move chamfer in timeline
(view in My Videos)
günther
Message 7 of 15
TheCADWhisperer
@tonyAQW8H
To expand on what @MRWakefield wrote.
Initially model as cosmetic threads, add the Chamfer, and then toggle to Modeled threads.
Message 8 of 15
MRWakefield
Yes, I meant to add that but forgot! Thanks for pointing it out.
Marcus Wakefield
Message 9 of 15
tonyAQW8H
Thanks for the reply.
I normally add the chamfer before the thread as it is easier to add it to a plain hole and then I move it to after the thread. For some reason it wouldn't allow me to move it in this model and when the thread just disappeared I didn't get around to sorting that.
I'm surprised it is showing 5 faces selected as I was only applying the offset to the middle hole so I only intended to select 3 faces. If one face in each of the other two holes was also selected I guess that explains why those threads went to a point it still doesn't explain why the thread in the middle disappeared though or have a misunderstood your explanation?
Message 10 of 15
tonyAQW8H
Thanks for the tip, that's a good way to do it.
I normally move it in the timeline but it wouldn't move on this model and then the missing thread issue overtook that issue.
Message 11 of 15
MRWakefield
Sorry no, I've no idea why the thread disappeared! Hopefully my posts helped you in some way though.
Marcus Wakefield
Message 12 of 15
g-andresen
I noticed that I cannot select the unselected face with the "Offset Faces 6" function.
However, this is possible when I create "Offset Faces" (in front of 6.) again.
This indicates a (temporarily) damaged tool.
I have experienced such behavior (rarely), but with different functions. If there are repeated problems with such functions, I redo them.
günther
Message 13 of 15
MRWakefield
That's pretty much what I experienced. It really wasn't acting as it should so I too deleted the offset and recreated it.
Marcus Wakefield
Message 14 of 15
tonyAQW8H
Hi günther
Thanks for the reply.  That is interesting, maybe that's what has happened in this case.
Has anyone loaded the model I posted and seen the same disappearing thread issue?
EDIT: Just seen Marcus has answered this question so it looks like you are correct.
Thank you everyone for your help and advice
Message 15 of 15
MRWakefield
Just a quick note: One caveat to my statement regarding the offsetting is that this only works on 60° threads. Anything other than this will cause errors in the form. In these cases the flank needs to be offset by a different amount to the Major and Minor dias. A better way to do it is to create a thread file with the extra clearance added to or subtracted from the Major, Pitch and Minor dias.
Marcus Wakefield
