Threaded rod joined to offset threaded hole in pipe
I have two components.  The first component is a pipe with a threaded hole in it offset like a chord through the pipe.  The second component is a threaded rod.  How can I get the threaded rod to join with the pipe through the offset threaded hole.
Thanks ahead of time.
Tom
jeff_strater
you are probably going to have to create some helper geometry, most likely a sketch.  I recorded a screencast, which I'll post when it is finished, of one way to do this.
Jeff Strater
Engineering Director
jeff_strater
here is the screencast:
Jeff Strater
g-andresen
try it this way:
günther
