Thread operation
Thread operation
chrisTVJG9
Message 1 of 8
Thread operation
chrisTVJG9
I design a threaded bolt as a component, I then make a nut using the same thread as the second component, Then select Joint and can find the centre of the bolt and select, then go to find centre of the nut and it appears when pointer is on the actual nut but disappears when you move to the empty centre of the nut thread so cannot make the bolt thread centered on the nut, what am i doing wrong
Replies (7)
Message 2 of 8
jhackney1972
Take a look at the screencast.  If you do not hover over the edge of the tapped hole at least once, you may not get the joint origin to show up at the center.
John Hackney, Retired
Message 3 of 8
chrisTVJG9
Message 4 of 8
chrisTVJG9
Not sure how i send the screencast but watched the screencast you did and thought i understood it but still on mine i can select the bolt but not the centre of the nut
Message 5 of 8
jhackney1972
I think the difficulty you are having is because you are selection one of the many points around the thread hole instead of the center joint origin, when it shows.  Take a look at the screencast.
You can learn about screencast at this link.  It is way down in the article so be sure to scroll down.  Screencast are pasted in the box right below the message body where it says "Paste a Screencast URL".  After creating a screencast, using the Autodesk Recorder, you can pick up the URL from the listing of your recording.
Message 6 of 8
jhackney1972
I am sorry, I forgot to add the link I spoke about.  Here is is.
Message 7 of 8
chrisTVJG9
Many thanks folks it was the hitting the spot i was not getting, now all understood untill no doubt the next time
Once again many thanks
Chris
Message 8 of 8
jhackney1972
Please mark your forum question solved so it is removed from the forum list and also to make it available as a solution to other users who may have the same issue.
