Message 1 of 10
03:29 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I realized that when I make a thread by using the command "Thread", the thread does not render. When I make a thread by modelling a coil and use that as tool to combine/cut, it renders just fine. Furthermore it also does not take the appeareance
Is this a bug or a feature? If it is a feature, can someone explain me what it is used for? For drawings? It is not needed for CAM because you can choose to cut a thread by toolpath in the CAM workspace.
If it is a feature i think it would be great if there was some documentation in the corresponding tooltip.
Appreciate your help, thanks
Timo
