Thread Clearance checkbox - am I dreaming?
jamyers63
Message 1 of 13
jamyers63
A couple days ago, I designed a part with threaded holes (modeled for the first time) for 3d printing.
I swear there was a checkbox that added Thread Clearance...
Printed the parts, and the thread clearance needs adjusting, so I went back in to edit that feature, and for the life of me I can't find any Clearance settings.
Did it go away with the update, or am I dreaming the whole thing?
Accepted solutions (3)
Replies (12)
Message 2 of 13
TheCADWhisperer
@jamyers63
You probably saw this - but it doesn't do what you think it does.
With a bolted connection you normally have a clearance hole through the first part, so the fastener drops through and then threaded hole in the second part.
There are Standards for the type of fastener and clearance that Fusion can automatically apply.
You will have to offset the faces of the thread for 3D printing manually as this is not a Standard.
Be sure that you have chamfer lead in too and that is done correctly (often not done correctly).
Message 3 of 13
MRWakefield
Unfortunately you dreamt it! As @TheCADWhisperer mentioned, I think you may have mistaken the purpose of "Clearance" hole option in the Hole dialogue.
In addition to any (excellent and valuable) guidance that @TheCADWhisperer will give you, you'll also find a link in my signature below that explains the hows and whys of thread offsetting. Many people get this wrong and it is important to understand what the undesirable effects can be of getting it wrong.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 4 of 13
jamyers63
Gotta love dreams! In mine, the thread clearance was an option in the Thread tool, not the Hole - I'm familiar with the Hole Clearance...
At any rate, thanks for confirming that I was only dreaming and not completely blind!
I tried to attach the .3mf files, but got this error message: "The attachment's wing bolt.3mf content type (application/octet-stream) does not match its file extension and has been removed."  - but no worries, they printed fine, just a bit snug and I'll offset the faces appropriately.
Thanks again!
Message 5 of 13
jamyers63
Hey, Thanks for the thread on Threads - great info there!
Message 6 of 13
MRWakefield
I expect @TheCADWhisperer wanted the F3D files rather than the exported mesh files.
Marcus Wakefield
Message 7 of 13
jamyers63
DOH! I saw 3 and quit thinking... my bad.
Message 8 of 13
TheCADWhisperer
@jamyers63
I see multiple issues with your modeling techniques.
Would you like to see better techniques?
Message 9 of 13
jamyers63
Sure, always looking to improve!
Message 10 of 13
TheCADWhisperer
@jamyers63
I am headed to the beach.
If I forget to get back to this discussion - bump it back to the top.
Stay tuned!
Message 11 of 13
jamyers63
Bump.
Message 12 of 13
TheCADWhisperer
@jamyers63
See Attached video and file.
(view in My Videos)
Message 13 of 13
jamyers63
That is AWESOME!!! Thanks for the pointers - lots of stuff I'll try and remember to use.
