Thin walls not displaying properly
sambirchenough
Message 1 of 21
sambirchenough
Is there a way to make these thin walls (.05mm) appear properly? The black body is between the two yellow bodies shouldn't show through. It shows through differntly at various zoom levels but does not appear correctly in Keyshot either (which a bigger problem). FWIW, they don't appear correctly with a .2mm thickness either but it is slightly better. Thanks!
founder @ BRCHN Design House
Replies (20)
Message 21 of 21
mcramblet
I've been testing just about every render engine that has Rhino integration. Maxwell, Iray, Arion, V-ray, Thea and Octane. Since I have Rhino and I still use it along with Fusion, I wanted to try the Rhino integrations. After trying all of these, Thea has (in my opinion) has the best Rhino integration. I've also tried the network capabilities of all and the Thea network rendering is pretty easy and works well. Any combination of Mac or PC's, any combination of CPU or GPU's. I like the fact that Thea is so versatile with its rendering, CPU, GPU or CPU+GPU, and biased or unbiased rendering. I'm 99% sure that I'm going to be ditching Keyshot pretty soon and switching to Thea. I'll be at least starting out with Thea for Rhino, but it's nice that I have the option to use the stand-alone version, too. I'm pretty impressed with Thea.
