Thicken error
Thicken error
Thicken error
Hey, I'm getting an error using the Thicken command in both the Model workbench and Patch workbench.  Unfortunately, the error doesn't help me much in the way of understanding the specific problem.  As you can see from the screenshot, the error is "The operation could not create a valid result. Try adjusting the values or changing the input geometry."
FYI, I'm trying to thicken an offset (Body 6 in the project).   My hope that is that I can thicken not just in one direction, but in a way that is normal to one side of the surface.  I'm thinking this is different than enlarge.    Can someone suggest what I can do to achieve my goal?
Thank you!
Here is the design file:
http://a360.co/2F6k1lO
laughingcreek
This is not the kind of thing Fusion excels at.  I suggest taking the original mesh model and editing in a mesh editor.  This would be easy in Mesh mixer or blender.
