Thermal Simulation Results
lelouchparanoid
lelouchparanoid
How do I derive the "Heat Loss %" that is happening from the heatsink based on the results?
shekar_sub
There is no Heat Loss result that is available in Fusion 360 Thermal studies. A manual calculation will involve computing the face area and multiplying that by the heat flux on a face (which could be in any direction) to get the total heat through the heat sink surfaces.  . Thanks
Best regards
Shekar
igor.krolikowski8YYUQ
In Autodesk CFD, there are heat loss calculations. It is possible to calculate the factor (W/m2dT) per particular surface (heat flux).
https://knowledge.autodesk.com/support/cfd/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/SimCFD/fi...
Igor Krolikowski
Software Development Manager
Product Design & Manufacturing
Autodesk, Inc.
