Thermal simulation gives negative result, with 0C held temp.
rbameMA3EK
rbameMA3EK
I have an outer wall set to an applied temp 0C and multiple heat loads on a circuit board. The path to this 0C is the only way heat can flow.
There are a couple negative temps showing up, i.e -1.478C shown in the attached image.  Any ideas why?
henderh
Hi @rbameMA3EK,
I agree, that doesn't seem correct. Would it be possible to share the model setup so we can take a closer look?
You can either post a link to download the model, use File -> Export and email it to me directly at hughDOThendersonATautodeskDOTcom.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
rbameMA3EK
Link to model.
https://a360.co/3axR4Kz
