Thermal Simulation Application - Cooling Electric Motors
Hey everyone I had some fun with thermal simulations in Fusion 360 the other day and wanted to share this example! It's a pretty practical application of running a quick thermal simulation for relative comparison purposes. That is to say, I don't expect this simulation to be absolutely correct because of the assumptions made during the analysis process, but I expect the relative results between different simulations with a similar setup to contain meaningful data that I can use. In this example it's specifically the expected temperature drop with a heat sink.
Here's the first video exploring the problem, analyses and possible options for resolution:
And here's the second video where we actually do some testing!
If you have any questions please feel free to ask!
lucasliraAU
Congratulations, great work!
I'm thinking of developing a 4x4 now I can get some ideas here 🙂
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
