Texture extrude texture map controls not showing
Stevencorzyk
Observer Observer
Stevencorzyk
Observer
Observer
Hello, did the projection controls get removed from the texture extrude feature in the direct edit mesh environment? the projection type used to be listed directly below the opacity in the pop up window, but now I am not seeing it. Right now this only allows you to project planar, and something like a cylinder would benefit from the other types previously listed.
rosie_lucas1
Hi @Stevencorzyk
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Rosie | Community Manager
Stevencorzyk
Observer
Observer
hello! No I have not yet found a solution to this, I have also verified with this education license, a hobbiest license, and pro license, none show the options I mentioned any more.
Thanks for the reply and help
Sualp.Ozel
The online help is wrong https://help.autodesk.com/view/fusion360/ENU/?guid=MESH-TEXTURE-EXTRUDE
We did not release those projection type options in Fusion.
we hope to do that in the future.
-Sualp Ozel
Sualp Ozel, PE
Principal Product Manager
Stevencorzyk
Observer
Observer
Thanks Sualp! Good to hear from you.  I really hope to see this enabled in an upcoming release, you guys are continuing to set the standard in affordable tools for education and industry, especially for those in the additive manufacturing space.
TheCADWhisperer
@Stevencorzyk
I suspect there is a better way to do this.
