- Mute
- Permalink
- Report
When using text in sketch mode we want to place a text on a component to e.g. engrave or laser print. After setting the text height and typing in the text the text will appear inside a construction box. We can then position the text on the component using the construction box as a reference for our position constraints.
Unfortunately the text is not the size that was entered - the construction box is the entered size but the text is smaller. This makes accurately positioning the text impossible unless you measure the text after extruding it on the component surface and then readjust the position. Also, the text is not the demanded height.
Or, have I got something wrong - pleased to hear any comments
All the best,
p,k,w
