Text on loft body
Text on loft body
technewbie
Text on loft body
technewbie
Hi
is it possible to deboss text into a lofted body so that the text follows the curvature of the loft?
Drewpan
Not really. It depends on how curvy the loft is. If it is a gentle curve then it works. If the curves are wavy with a lot
of depth it doesn't really work well. It may work better to create the loft as a surface, cut the text out and then
thicken the surface to get the deboss effect but that may not work well either. It simply depends on the loft.
Cheers
Andrew
g-andresen
In this case, extrude from object works better.
günther
SaeedHamza
The problem actually lies withen the sketch you're using, as Fusion doesn't handle imported dxf lines that well.
I've played alittle with the sketch and recreated some lines and the emboss worked just fine. File is attached.
Saeed Hamza
technewbie
Perfect. Thank you
