Text Not Extruding Completely on Solid Surface
poophappens
Observer Observer
poophappens
Observer
Observer
I'm trying to extrude text on a solid surface but running into an issue where the text isn't extruding completely on a certain character (specifically the capital "A").
The font I'm using is  InterTight-Light.ttf.
https://fonts.google.com/specimen/Inter+Tight?preview.text=AAAAaaaAAAA
Here's the issue:
If I explode the text then extrude the whole sketch:
If I select the whole text, then deselect the inner shapes and extrude:
Is this the only way to fix this issue? Exploding the text is not ideal if I need to edit it in the future.
jhackney1972
Probably so.  If you will notice the overlap of geometry in the Exploded text is a good sign it is a poorly created font.
John Hackney, Retired
