Text in sketch doesn't work in rectangular frame.
d.zawada
d.zawada
Today, after some time, the text in the sketch (rectangular) has stopped working. The text on the path works fine, but if I try to add a rectangular text box, the options for placing the text and changing its settings are not displayed. Does anyone know this problem?
jeff_strater
I have not been following this topic very closely, but there is a problem that others have reported, but does not affect everyone.  I think it might be related to a second monitor.  Can you try disconnecting a second monitor if you have one, and re-start Fusion?  Does it work if Fusion is on your main screen?
Jeff Strater
Engineering Director
d.zawada
Yes, you are absolutely right. When I draw a text box on the main monitor I'm fine, but when I drag it to the second or third, the rectangular text box doesn't work. An interesting fact is that I didn't restart fusion after dragging the window. Just drag it to the correct monitor and the function is back. Thanks a lot for help.
