Tapered thread
Tapered thread
Oluwayimika_OLA
Message 1 of 8
Tapered thread
Oluwayimika_OLA
Hi, is there a way I can create a tapered thread model. I tried using the thread command on a tapered face from the circle I extruded, but I could even select the face. I tried moving it back in the timeline but it didn't show the threaded surface
Replies (7)
Message 2 of 8
Drewpan
What is the purpose of a Tapered Thread? A standard thread or screw have clamping properties
that allow them to securely hold in place. A tapered thread would reduce those holding forces
and possibly not hold at all. Any thread will certainly prevent movement in the "upwards"
direction but a tapered thread probably would still allow rotation and not lock as securely and
maybe not lock at all.
Cheers
Andrew
Message 3 of 8
a.laasW8M6T
Tapered threads are used in numerous applications, but most commonly for sealing Fluid fittings using either BSPT or NPT standards.
Andrew Laas
Senior Machinist, Scott Automation
Message 4 of 8
Drewpan
Thanks for that. I have not come across them before. If you have a tapered thread
then wouldn't that affect how the threads lock down? As the thread gets "thicker"
it would get to a point where the thickness would prevent the thread from engaging
any further, sort of like a wedge? A normal thread locks due to friction between the
threads pulling them into each other. Wouldn't a wedge be a much weaker lock?
Is there any specific advantage to use tapered threads for fluids or is it some
traditional thing? I do know that threads can sometimes leak with fluids.
Cheers
Andrew
Message 5 of 8
davebYYPCU
Is there any specific advantage to use tapered threads for fluids,
Yes.  they are very common in fluid handling regimes - which rarely requires any clamping effect
They are designed to work efficiently in the tightening direction. to avoid
 ... (standard) threads can sometimes leak with fluids.
Might help....
Message 6 of 8
TheCADWhisperer
Message 7 of 8
etfrench
A tapered coil can give you a close approximation of a thread. Create the coil. Revolve/Join a solid cone to create the proper valley width.  Revolve/Cut another cone to create the proper crest width.
 A sweep may give you a better thread form.  Pipe should work but doesn't.
ETFrench
Message 8 of 8
Oluwayimika_OLA
  1. I'm back to this comment to say the solution is profound
