tangent constraint with spline and line
Nkose
452Aufrufe
3Antworten
Nachricht 1 von 4
Nkose
I can't add tangent constraints between spline and line.
0 „Gefällt mir“-Angaben
453Aufrufe
3Antworten
Antworten (3)
Nachricht 2 von 4
dikshant.
A fit point spline already has tangent lines. If you still want to create a new line, you can do so either by - using line command, selecting coincident constraint between line and point, dragging the line until it is tangent to the spline or you can making a line parallel to the pre-existing tangent line and with the help of other constrains, likely achieve the desired result.
Nachricht 3 von 4
MoshiurRashid
Hi
Thanks for posting. I've created a screencast for you to describe different ways to tangent a spline with line.
Click here to watch the screencast
This might help you
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Nachricht 4 von 4
g-andresen
Is there a reason why you are not uploading a file such as suggested in your last thread on this topic?
günther
