T Spline Surface Self Intersects
Im making these headphones for a class project!. And ive come across this small problem before i can convert my body. Any ideas on how i can fix this
NicolasXu
Hi amck3nz13,
You may enable the Box display mode and check the T-Spline quality. There are multiple ways to switch the display mode.
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
deyop
Here is a video that may help explain how self-intersection problems are identified and repaired.
Identifying and Repairing T-Spline Conversion Errors
Is there a way to zoom to the error as I have a case where a self-intersect is reported but I can't see it! 🙂
It would be good to be able to toggle through all the errors that need to be addressed.
Cheers,
Jon
laughingcreek
This may not be related to your troubles, but I thought I would share something that causes this type of problem for me frequently, just in case.
 Sometimes when doing funky things with a tspline, the tangent controls get unlinked from their vertices's.  This can make a tspline body look just fine in box mode, but be completely messed up in smooth mode.  You can tell if this has happened by going into edit form and selecting the vertices's selection filter.  Un-less you've moved them on purpose, all the tangent control points should be green (you may need to change the opacity of the body to see all of them).  If any of them are red, then they have become unlinked.  This video demonstrates this pretty good, and shows the command to fix it.
http://forums.autodesk.com/t5/post-your-tips-and-tutorials/stuff-you-need-to-know-tangent-handles/m-...
Hey, that video doesn't appear to be there. Any reference to a new one?
